1991 Pontiac Grand Prix 91 Grand Prix GTP 3.4L
1991 PONTIAC GRAND PRIX
99,982 MILES • 6 CYL • FWD • AUTOMATIC
MOTOKING_1990
  • 10 POSTS
I have a 91 Grand Prix GTP with the 3.4L and was driving it the other day and got on the gas a little and then it just died! The motor cranks over but doesn't start the tach doesn't go up when you crank it like it should either! The spark plugs do have spark and i went ahead and replaced the Crank Shaft Sensor and it didn't help. Also, I replaced the fuel pump, ignition module, and coils, plugs and wires, alternator and battery a few months before! If anyone has any ideas on what could be wrong it would be greatly appreciated!!! Thanks
Sep 15, 2010 at 8:54 PM
MMPRINCE4000
  • 8,548 POSTS
Spray some starting fluid into intake to rule out fuel.
Sep 16, 2010 at 9:01 AM
MOTOKING_1990
  • 10 POSTS
I have sprayed starting fluid and it doesn't do anything the car only has 99 thousand on it.
Sep 18, 2010 at 5:35 PM
MMPRINCE4000
  • 8,548 POSTS
Start checking fuses and fuseable links, it sounds like you have changed most ignition components.
Sep 19, 2010 at 8:35 AM
MOTOKING_1990
  • 10 POSTS
turns out the timing belt stripped out!
Oct 4, 2010 at 3:54 PM
MMPRINCE4000
  • 8,548 POSTS
Great news. Thanks for using 2carpros.
Oct 5, 2010 at 9:55 AM
