o2 sensor location
PONTIAC GRAND AM
DECKJ
  • 7 POSTS
hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?
Aug 23, 2006 at 7:34 PM
MIKEYBDMAN
  • 623 POSTS
[quote:47446d34a0="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote:47446d34a0]
which engine do you have?
Aug 23, 2006 at 7:35 PM
DECKJ
  • 7 POSTS
[quote="Mikeybdman"][quote="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote]
which engine do you have?[/quote]
i have a 3.1 v6
Aug 23, 2006 at 7:36 PM
MIKEYBDMAN
  • 623 POSTS
[quote:4bc284fe8d="Mikeybdman"][quote:4bc284fe8d="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote:4bc284fe8d]
which engine do you have?[/quote:4bc284fe8d]
On a V6 model the HO2S1 is located in the rear exhaust manifold. Right before it connects to the exhaust pipe. The HO2S2 is located behind the cat converter.
Aug 23, 2006 at 7:39 PM
DECKJ
  • 7 POSTS
[quote="Mikeybdman"][quote="Mikeybdman"][quote="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote]
On a V6 model the HO2S1 is located in the rear exhaust manifold. Right before it connects to the exhaust pipe. The HO2S2 is located behind the cat converter.[/quote]
thank u very much. you responded quite quickly too. i think i know where it is then. there isnt anything i could be getting it mixed up with is there?
Aug 23, 2006 at 7:42 PM
MIKEYBDMAN
  • 623 POSTS
[quote:1ffc3c7d1c="deckj"][quote:1ffc3c7d1c="Mikeybdman"][quote:1ffc3c7d1c="Mikeybdman"][quote:1ffc3c7d1c="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote:1ffc3c7d1c]
which engine do you have?[/quote:1ffc3c7d1c]
On a V6 model the HO2S1 is located in the rear exhaust manifold. Right before it connects to the exhaust pipe. The HO2S2 is located behind the cat converter.[/quote:1ffc3c7d1c]
thank u very much. you responded quite quickly too. i think i know where it is then. there isnt anything i could be getting it mixed up with is there?[/quote:1ffc3c7d1c]
Nope. Should be the only sensor with wires going to it in the exhaust manifold.
Aug 23, 2006 at 7:43 PM
