Yes it is possible. However it is (almost) never a good idea. Generally the throttle plate adjusting screw is sealed. It is sealed because if the idle is high it is usually a vaccum leak and adjusting the screw will only mask the problem, and can cause more damage by causing a lean condition.
Unless you had a backfire that bent the throttle plate, I would not touch the adjusting screw. The throttle body may be clogged up from the EGR or the IAC may not be working properly.
Feb 16, 2007 at 12:07 PM
