2004 Pontiac Grand Am Vibration - Buzzing sound
2004 PONTIAC GRAND AM
122,200 MILES • 6 CYL • FWD • AUTOMATIC
RAMSEY13
When my car gets up to 60mph or more there is a buzzing sound. If you slow down to 55 it is not there. Sounds like it comes from the dash or directly above the rear view mirror? I have never had this type of problem and I am lost.
Apr 25, 2009 at 2:31 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
While the sound is coming from inside, it may be a problem as described above or an alignment issue that is causing the buzzing inside.
Does car have power moon roof?
Apr 26, 2009 at 6:48 AM
RAMSEY13
Found that the weatherstripping at the top of the windshield had loosened. We reapplied Weathestrip adhesive and fixed it. Thanks
Apr 26, 2009 at 7:57 PM
MMPRINCE4000
  • 8,548 POSTS
Great news, thanks for using 2carpros.
Apr 27, 2009 at 5:16 AM
