2004 Pontiac Grand Am front door lock actuator
2004 PONTIAC GRAND AM
113,000 MILES • 4 CYL • FWD • AUTOMATIC
MISTIEBLUERN
Hi, my door lock actuator on the drivers side front seems to be broken. The bar that hooks the outside door handle seems to be unattached from the lock actuator. It is behind the metal door panel and very difficult to get to. The door will not latch closed. Any suggestions? Thanks
Aug 29, 2009 at 7:18 PM
MMPRINCE4000
  • 8,548 POSTS
Check for 12V at door lock switch, if present, then lock solenoid or as you suggest a mechanical connection.
You will have to remove the interior door panel to fix this.
Aug 30, 2009 at 7:10 AM
