2004 Pontiac Grand Am buzzing noises
2004 PONTIAC GRAND AM
62,007 MILES • 4 CYL • 2WD • AUTOMATIC
RCMYLOTT
my car has been making a loud buzzing noise that goes away when i turn right but comes back when i go straight or turn left. it also shakes a little while i drive
Sep 22, 2008 at 3:40 PM
MMPRINCE4000
  • 8,548 POSTS
Inspect the CV joint boots for tears/cracks/leaking lubricant. Check both inner and outer boots.
Raise vehicle, put on stands and grasp wheel, pull/push both horizontally and vertically, looking for any movement. If you have movement, then could be bearings/hub, ball joint, tie rods.
Also inspect brakes, making sure everything is tight.
Sep 23, 2008 at 7:17 AM
