2003 Pontiac Grand Am Stripped Rocker Arm Bolt Hole
2003 PONTIAC GRAND AM
CARRIEANN21
Engine Mechanical problem
2003 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
Ok how can i fix this myself with a helicoil and what do i torgue it to?
Oct 8, 2010 at 10:45 PM
HMAC300
  • 48,601 POSTS
you may be able to fix this but i kind of doubt it. You can try a heli coil but there is 200+ pounds of pressure to open the valve. The torque for the stud should be around 30 ft. lbs. Do yourself a favor and just replace the cylinder head, more exspensive, but it's done right and you won't need to do it twice....
Oct 9, 2010 at 3:31 PM
