At slow speeds I have very high steering effort on right hand turns but perfectly normal power assist when turning wheel left (regardless of wheel position). At higher speeds the issue is lessened, but still present to a degree. No fluid leaks, hoses appear OK, and no unusual noises from steering components. As a result, I think the pump is OK (provides pressure) and also the variable power assist valve (if it exists) must also be OK since it doesn't have any idea which direction you're turning the wheel (right?) So, have I talked myself into the correct conclusion, that the steering rack needs replacement?
many thanks!
many thanks!
Mar 7, 2010 at 3:40 PM
