2003 Pontiac Grand Am Check sensors
2003 PONTIAC GRAND AM
51,000 MILES • 6 CYL • FWD • AUTOMATIC
SAMANTHA1122
  • 7 POSTS
I need to know if there is a way to check the following sensors without having to have my car scanned.
-Mass airflow sensor
-Oxygen sensor
-Throttle position sensor
Jun 14, 2010 at 11:40 AM
BLACKOP555
  • 10,386 POSTS
you can test tps with a dmm hook to signal wire then a good ground. then move throttle from closed to wide open throttle should be a steady increase from .7v up to 4.5v
o2 sensor can be checked with dmm to see if its producing voltage from .1 - .9 volts constantly changing
maf you can check for power and ground but not really how its reacting the meter is too slow.
best thign is use a scan tooll or a oscillioscope
Jun 14, 2010 at 11:31 PM
