2002 Pontiac Grand Am Blinkers
2002 PONTIAC GRAND AM
GILMAD
Electrical problem
2002 Pontiac Grand Am 4 cyl Automatic 152,00 miles
The blinkers and hazard lights work properly. Once I use either one the sound of the blinker stays on and wont stop until I turn the car off. Can you tell me what needs to be replaced and how I can replace it?
Nov 7, 2008 at 12:21 PM
IMPALASS
  • 3,112 POSTS
Hello -- I would think it is a defective Hazard warning switch. On your model the Hazard Flasher and Turn Signal Flasher have been integrated with the Hazard Lamp Switch. I have attached how to change. HAZARD WARNING SWITCH REPLACEMENT - ON VEHICLE REMOVAL PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/248015_1_38.jpg
Remove the Instrument panel (IP) accessory trim plate. Remove the bracket screws from the IP accessory switch mounting plate.
https://www.2carpros.com/forum/automotive_pictures/248015_2_26.jpg
Remove the bracket.
https://www.2carpros.com/forum/automotive_pictures/248015_3_22.jpg
Use a small flat-bladed tool in order to depress and release the hazard warning switch retainers. Press the switch out with your thumb.
https://www.2carpros.com/forum/automotive_pictures/248015_4_11.jpg
Remove the hazard warning switch. INSTALLATION PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/248015_5_7.jpg
Position the hazard warning switch to the bracket.
https://www.2carpros.com/forum/automotive_pictures/248015_6_3.jpg
Install the switch to the bracket by pressing into place until fully seated.
https://www.2carpros.com/forum/automotive_pictures/248015_7_4.jpg
Position the bracket to the IP accessory trim plate. NOTE: Refer to Fastener Notice in Service Precautions.
https://www.2carpros.com/forum/automotive_pictures/248015_8_2.jpg
Install the mounting plate bracket screws to the IP accessory switch. Tighten Tighten the screws to 3 N.m (27 lb in) . Install the IP accessory trim plate.
Nov 7, 2008 at 10:55 PM
