2001 Pontiac Grand Am water leak
2001 PONTIAC GRAND AM
THENWHAT85
Air Conditioning problem
2001 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
the drain plug isnt clogged and water still comes out there but it also leaks in the car too. where it leaks is a crack in the plastic unit is there supost to water in that area. if i seal the crack will it stop leaking and not cause future problems
Aug 12, 2009 at 3:01 PM
MMPRINCE4000
  • 8,548 POSTS
If you have a crack in the radiator side tanks, you can try an epoxy to seal it, or replace the radiator.
Aug 13, 2009 at 8:32 AM
