The turn signals work about half the time. They will go for long stretches and work fine, then out of the blue they just will not work. I had the signal switch on the column replaced thinking that would solve it. But it did not change anything. Now the vehicle was in a slight accident a few years ago where the front right side was slammed into a high curb, resulting in the whole fender, axle, and etc had to be replaced. The signals worked for a while after the repairs, but now only half the the time. There does not seem to be any obvious reason that I can tell that causes them to just stop working or anything that then makes them begin working again. What should I check next or consider in order to make this vehicle safe to drive again. Currently using hand signals when they do not work.
Mar 6, 2010 at 7:00 PM
