2001 Pontiac Grand Am Turn Signals work some times
2001 PONTIAC GRAND AM
79,000 MILES • 6 CYL • FWD • AUTOMATIC
SACREDWOLF
  • 9 POSTS
The turn signals work about half the time. They will go for long stretches and work fine, then out of the blue they just will not work. I had the signal switch on the column replaced thinking that would solve it. But it did not change anything. Now the vehicle was in a slight accident a few years ago where the front right side was slammed into a high curb, resulting in the whole fender, axle, and etc had to be replaced. The signals worked for a while after the repairs, but now only half the the time. There does not seem to be any obvious reason that I can tell that causes them to just stop working or anything that then makes them begin working again. What should I check next or consider in order to make this vehicle safe to drive again. Currently using hand signals when they do not work.
Mar 6, 2010 at 7:00 PM
Could be a ground problem at G102 at left front shock tower or the hazard switch
Mar 7, 2010 at 3:18 AM
HOLLABAMA
Yea, that has been happening to me, too. I took it in and spent almost $600 on getting that switch replaced and the next day guess what...blinker didn't work when I was driving back from a meeting, but then worked fine a few blocks later. Hmm.
Taking back on Saturday, do you think if I give them that info, that might do the trick?
"Could be a ground problem at G102 at left front shock tower or the hazard switch"
I'd say it's about 20% of the time it doesn't work.
Mar 10, 2010 at 12:06 PM
