I WAS TRYING TO DO A TUNE UP ON MY CAR AND I WAS NOT ABLE TO LOCATE THE SPARK PLUGS OR IGNITION COIL.
Apr 25, 2008 at 1:00 PM
BLACKOP555
CERTIFIED EXPERT
if memory servs right yours is coil on plug design.
if you see no spark plug wires, whatso ever then its coil on plug and there is a separate coil for each plug, and it is located right on top of the spark plug.
pontiac has a knack for hiding other ignition system spark plugs such as DIS plugs are usually under the vehicle way up in the back. you will need a lift.
