[quote:093ef1765d="ddraskovich"]Engine Mechanical problem
1999 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 78000 miles
My car is idling at 3,000 RPMs. It also idles rough. When I drive, without pushing the case peddle, the car accelerates to 40 mph. At all driving times, the car will continue to accelerate until I hit the breaks, at which point it will begin accelerating again.
My car's service engine soon light is on. Do you have any idea of what type of problem I am experiencing?Even though my car has low miles, it is probably worth 2K at best, due to a recent accident causing a lot of body damage. Is my car even worth the cost of diagnosing and fixing the potential problem?
Thank you.[/quote:093ef1765d]
First thing I would do is go by your local auto zone and have them pull codes for you they will do it for free.
Post codes here in forum....
Also, it could be any number off things....
When was your last tune up?
Could be the IAC (Idle Air Control Valve), TPS (Throttle Position Sensor). So having codes pulled would greatly and quickly find problem.
Nov 4, 2019 at 12:23 PM
(Merged)
