2000 Pontiac Grand Am warning light indications
2000 PONTIAC GRAND AM
BML
Electrical problem
2000 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
a couple months ago, brake calipers, pads, and wheel bearings were removed and replaced. Now i'm having some trouble with indication lights on dash,,,service engine soon, service vehicle soon, abs light, trac off, and low track flickering on and off.... these are the same symptoms i had prior to changing the wheel bearings.... now they're back again....hoping strongly that the bearings are not the cause of all headaches right now,,,, any ideas??
Mar 20, 2010 at 2:54 PM
MIDDY
  • 30 POSTS
See if any of your friends have a code reader, and see what those "service soon" codes will tell you. That might be pretty helpful.
On each wheel there is a wheel speed sensor, and that feeds information to your antilock braking system. I think I'd want to inspect those sensors, as a starting point. But getting that code information would be most helpful.
Mar 20, 2010 at 7:22 PM
