The steering wheel does not seem to return to center after I take a left hand turn. At that time, it also pulls very hard to the left. If I stop, turn the wheel all the way to the right and then back to center, it will not pull to the left until or unless I make another left hand turn. I have had four different people look at the front end. They said the ball joints, the struts, the tie rod ends are O.K.. Only one found that the left side of the stabilizer bar (where the link bolt goes thru it) is cracked.
Can a cracked stabilizer bar cause this type of problem or would it tend to be an indication of something else, such as, a problem with the rack & pinion?
Please help.
Please help.
Aug 6, 2008 at 2:10 PM
