2000 Pontiac Grand Am Gauges
2000 PONTIAC GRAND AM
11,800 MILES • 6 CYL • FWD • AUTOMATIC
INDYDOG
When we start the car, all of the gauges swing all the way around, and then return to their normal positions, is this a sign of bad things to come?
Also the horn does not work and I would like to disconnect it at the steering column and install a remote horn switch, how do I find the horn wires and not fool with the airbag wires?
Thank you.
Mar 5, 2008 at 7:41 PM
MASTERTECHTIM
  • 4,750 POSTS
i usually find the horn problem is not in the steering column and is actually a faulty horn. i would not worry about the gauge swing thing. my suggestion is to check the battery terminals for tightness, sometimes a loose cable will make gauges go crazy. try checking the horn for power and ground with a test light and get back to us
Mar 7, 2008 at 2:27 PM
2CARPRO JACK
  • 11,533 POSTS
Pontiacs do that for some reason........ The only GM car I have seen do it, but they all do
Mar 8, 2008 at 8:27 AM
