1999 Pontiac Grand Am WATER COMING OUT OVER FLOW
1999 PONTIAC GRAND AM
120,000 MILES • 6 CYL • FWD • AUTOMATIC
NIKKISPARKS
  • 12 POSTS
WE JUST GOT IT WE WERE DRIVING AND HEARD A LOUD THUMPING THE WATER RESEVOIR WAS SWOLLEN AND JUMPIN ALLL WATER WAS GONE WE REPLACED WATER PUMP ABD RADIATOR BUT STILL WHEN IT RUNNING THE WATER POURS OUT THE OVER FLOW WHAT WRONG DO YOU THINK
Jan 2, 2009 at 7:40 PM
BUDDYCRAIGG
  • 2,262 POSTS
over heating or a blown head gasket.
Jan 2, 2009 at 7:58 PM
NIKKISPARKS
  • 12 POSTS
ISNT A BLOWN HEAD GASKET EXPESIVE BUT IT DOESNT OVER HEAT
Jan 2, 2009 at 10:04 PM
BUDDYCRAIGG
  • 2,262 POSTS
repairing a blown head gasket can be expensive.
but let's try to figure out what is going on.
if the head gasket is really bad, (as compared to a small leak) the pressures in the combustion chamber will immediately start to over pressurize the coolant system.
if it's happening because it's over heating, (say because the thermostat isn't opening) it would take a few minutes
and you can't completely trust your temp gauge or warning light when it comes to a situation like this.
if there is air in the system (or steam ) the temp sensor isn't effected much because air and steam don't transfer heat as well as water does.
Jan 2, 2009 at 10:21 PM
NIKKISPARKS
  • 12 POSTS
THANKS YOUR HELPFUL THE THERMOSTAT WILL BE FIXED TOMMORROW BUT WE DROVE THE CAR A FEW TIMES IT DIDNT DO IT BUT WE ONLY WENT LIKE 5 MILES TOO BUT A SHOP TOLD US THE INTAKE MANIFOLDS WERE LEAKING OIL AND COOLANT BUT COME TO FIND OUT THIS SHOP IS CROOKED AS CAN BE BUT I WILL LET YOU TOMMORROW IF IT WORKS BUT I AM FROM FRANKLIN COUNTY MISSOURI KNOW ANY GOOD SHOPS
Jan 2, 2009 at 10:29 PM
BUDDYCRAIGG
  • 2,262 POSTS
it's a small world.
I'm in Kansas City MO.
the shop may not be wrong about the intake manifold leaking.
the 60degree V6 Chevy engine, (2.8, 3.1, and 3.4) are known for having a problem with the intake gasket.
GM has come out with an updated gasket kit to help solve the issue.
but normally the leaking gasket would not cause the problems you are having
Jan 2, 2009 at 10:35 PM
NIKKISPARKS
  • 12 POSTS
OK WELL I AM CLUELESS I JUST NEED MY CAR RUNNIN I START NURSING SCHOOL IN 2 WEEKS AND I AM BROKE SO HOPE FULLY ITS A LITTLE PROBLEM CUZ I ALSO HAVE A JEEP THAT STALLS WHILE DRIVING THANK YOU SO MUCH FOR YOUR TIME
Jan 2, 2009 at 10:49 PM
NIKKISPARKS
  • 12 POSTS
ok so we got thermostat installed but the guy who was fixing it well when he was tighting the lower bolt on the housing the hole it screws into which is the one on the motor part broke so he used jb weld to hold the housing on what do you think he said not to drive for 24 hours
Jan 3, 2009 at 4:12 PM
BUDDYCRAIGG
  • 2,262 POSTS
i cant speculate if it will work or not.
while i do think JB Weld is an excellent product, it is not a magical potion that can fix everything.
good luck
Jan 3, 2009 at 4:21 PM
NIKKISPARKS
  • 12 POSTS
If not whats my other option to fix it? this my last question thanks for you help
Jan 3, 2009 at 5:13 PM
BUDDYCRAIGG
  • 2,262 POSTS
i would have to see how it is broken.
if the threads are just stripped out, a heli-coil would most likely work.
if part of the casting broke away because the bolt was hydrolocking in the hole with gasket maker in it. that's something that would just have to be looked at in person.
and you can ask as many questions as you want.
Jan 3, 2009 at 5:43 PM
NIKKISPARKS
  • 12 POSTS
wow your helpful i wished u lived closer you seem like a good mechanic but its the casting i guess instead of a whole circle its half of one
Jan 3, 2009 at 7:17 PM
BUDDYCRAIGG
  • 2,262 POSTS
thank you for the kind words,
[quote:c05e7eda0e="nikkisparks"] its the casting i guess instead of a whole circle its half of one[/quote:c05e7eda0e]
that's not a good thing.
It may be possible for the hole to be drilled deeper.
then threads cut in the hole with a tap.
and a longer bolt be used in it's place.
but someone with experience should probably look at it to determine if that is possible
Jan 3, 2009 at 7:43 PM
NIKKISPARKS
  • 12 POSTS
Great well thanks for your help i am just gonna give up on it i cant fork out what shops want
Jan 3, 2009 at 8:10 PM
BUDDYCRAIGG
  • 2,262 POSTS
dont give up.
wait until tomorrow and see if it leaks.
(i'm the only one that gets to be a pessimist around here)
Jan 3, 2009 at 8:43 PM
NIKKISPARKS
  • 12 POSTS
ok another question we had a shop tell us a while ago that our intake manifold were leaking oil and coolant what problems will that cause and how neccassary is it to fix
Jan 4, 2009 at 12:41 PM
BUDDYCRAIGG
  • 2,262 POSTS
it depends on how bad the leak is.
worst case, is it would leak water into the engine oil and the bearings would be destroyed pretty quickly.
you probably wouldn't still be driving it if that was the case.
most commonly, a little bit of water is sucked into an intake runner and is vaporized and sent out the exhaust.
you would probably be noticing white smoke.
either one could cause the engine to over heat
Jan 4, 2009 at 1:41 PM
NIKKISPARKS
  • 12 POSTS
ok well step dad said the oil looks kinda nasty like it has water in it i dot know this stresses me out what if it mixed with oil what repairs should be done
Jan 4, 2009 at 1:44 PM
BUDDYCRAIGG
  • 2,262 POSTS
does the oil looks like a chocolate milk shake?
if yes, then you need to stop driving the car until the intake gasket is fixed.
then change the oil a couple of times in a row to get the water out.
and hope no engine damage has already happened.
Jan 4, 2009 at 1:48 PM
