1999 Pontiac Grand Am steam
1999 PONTIAC GRAND AM
117,670 MILES • 6 CYL • FWD • AUTOMATIC
PATSY541
During inspection my mechanic said that I needed to replace the intake ??? - something to do with the engine. Yesterday I saw steam and thought that it was caused by the rust protection. Today it was steaming much more and actually the low coolant light came on. In the morning things are fine, however on the way home, it acts up. I also observed that the overflow container has little bits of black stuff and I planned to clean it out in the spring. The cooling fan at 3 is very hot and blows hard and at 2 nothing happens. My question is, what is the proper diagnosis and estimated cost? Although made in the USA, this car is now in Canada. Would I have a great car for the winter? Thanks for your answer.
Dec 11, 2008 at 8:57 PM
MMPRINCE4000
  • 8,548 POSTS
He was probably talking about the intake manifold gaskets.
GM has had many problems with the 3.4 and 3.8 intake manifold gasket failing.
Generally blamed on the "DEXCOOL" coolant they use.
You want to get this fixed ASAP, if coolant gets into the oil, you may be looking at a new engine.
Dec 12, 2008 at 8:31 AM
