1999 Pontiac Grand Am Oil Pump
1999 PONTIAC GRAND AM
KESHIA79
  • 4 POSTS
Engine Mechanical problem
1999 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
How do you take the oil pump off of 1999 Pontiac Grand Am SE.
Feb 26, 2010 at 1:27 PM
SCOTTY DEE
  • 592 POSTS
Drop the oil pan, it's bolted to the bottom of the engine.
Feb 26, 2010 at 1:34 PM
KESHIA79
  • 4 POSTS
There's a chain on there how do I remove the chain to get to the oil pump?
Feb 26, 2010 at 1:58 PM
SCOTTY DEE
  • 592 POSTS
Remove the balance shaft chain cover. Remove the balance shaft chain tensioner assembly. Remove the oil pump cover. Remove the oil pump. Installation Procedure Install the oil pump
https://www.2carpros.com/forum/automotive_pictures/470594_84945124_1.gif
Install the oil pump cover to the balance shaft housing. Tighten the bolts to 54 Nm (40 ft. lbs.) . Install the balance shaft chain tensioner. Important: You must use a brass feeler gauge in order to obtain correct measurements. A steel gauge will not conform to the guide and will not provide correct measurements.
Feb 26, 2010 at 2:05 PM
