Hello
A miss fire could be several things. Faulty spark plug or wire, Faulty coil (pack), Faulty oxygen sensor(s), Faulty fuel injector, Burned exhaust valve, Faulty catalytic converter(s), Running out of fuel, Poor compression, Defective computer.
My suggestion. You have replaced many of these things. I would think if it were a oxygen sensor, you should get that code. I don’t think it is a faulty catalytic converter or defective computer. You are going to have to be able to clear the code and check each time for this or end up taking it somewhere. Auto Zone or O’Reilly’s may let you buy/return under the tool loan program the tester for codes.
First since you have replaced numerous things, do a compression check on all the cylinders. If number one is really low, then you probably have a burnt valve. If all okay or close to the same, then I would do the below next.
Starting simple, you can crack a plug putting it in. I would clear codes, swap #1 plug with another cylinder. Drive it see what you get. If you get number one again, then swap the plug wire, clear the code and try it again. If you get number one, swap fuel injector. If any of these moves to the other cylinder then you have found the problem and you replace that part.
From what I see to test the fuel pressure you would need disconnect the fuel line, hook the pressure tester to the end, have a tester to turn on the fuel pump and then see what the pressure is.
It appears you need some test equipment for some of this. Why don’t you do the easy things above and let’s see what you come up with from there.
If it were a steady misfire and running rough, you could isolating the misfiring cylinder the old-fashioned method for finding a weak cylinder is to temporarily disconnect each of the spark plug wires, one at a time, while the engine is idling. When there's no change in the idle speed, then you have pinpointed the weak cylinder. Careful though, if the spark jumps to you it isn’t going to feel good.
My bet with that many miles is a bad fuel injector or fuel pump. But let’s see.
Oct 22, 2008 at 8:56 PM
