1999 Pontiac Grand Am front end wobble
1999 PONTIAC GRAND AM
118,000 MILES • 4 CYL • 2WD • AUTOMATIC
I HAVE A 1999 GRAND AM THAT WOBBLES ON THE FRONT WHILE DRIVING. THE STIRRING WHEEL ALSO WILL SHAKE A LITTLE. I WOULD LIKE TO KNOW WHAT THIS MIGHT COULD BE AND WOULD IT BE EXPENSIVE TO FIX
Apr 13, 2009 at 12:00 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
If you have no movement after performing the above, then tire, alignment problem.
Apr 14, 2009 at 8:28 AM
