my blower motor has been acting up and stops?
1999 PONTIAC GRAND AM
BLIZZARDBLIND
Heater problem
1999 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 156k miles
my blower motor in my 99 grand am has been acting up 1 night after i absentmindedly left it running for like 2 hrs, it'll blow when the car hasn't warmed up yet, or even when i take a hard left it'll kick on full power, otherwise it'll turn on for a second then off again. Also if i hit the underboards beneath the glovebox it'll start up weakly sometimes. I'm not too saavy w/ the troubleshooting aspect of vehicles so was wandering if maybe it could be some relay, bad ground, loose connection. any advice would be much appreciated, I live in northern mn and it's been below zero the past 2 days and this weekend might get down to -40 or so w/ the windchill, I need my heat! Thanx for your time
Jan 17, 2008 at 2:12 PM
BMRFIXIT
  • 19,053 POSTS
[quote:5ec9e4f239="blizzardblind"]Heater problem
my blower motor in my 99 grand am has been acting up 1 night after i absentmindedly left it running for like 2 hrs, it'll blow when the car hasn't warmed up yet, or even when i take a hard left it'll kick on full power, otherwise it'll turn on for a second then off again. Also if i hit the underboards beneath the glovebox it'll start up weakly sometimes. I'm not too saavy w/ the troubleshooting aspect of vehicles so was wandering if maybe it could be some relay, bad ground, loose connection. any advice would be much appreciated, I live in northern mn and it's been below zero the past 2 days and this weekend might get down to -40 or so w/ the windchill, I need my heat! Thanx for your time[/quote:5ec9e4f239]\\\\
most likely you need a new blower motor
it sounds to me as if the brushes in the motor
Jan 17, 2008 at 4:22 PM
TOMMYMUSTANG
The heater fan will cut off inexplicably and may come on again when I hit a bump in the road. The fan speeds work when the fan is operting properly.
What must be removed to access the fan motor.
Nov 9, 2024 at 4:51 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
you are on the right track it sounds like its the blower motor
its on passenger side
ez to do
I agree with BMRFIXIT, here is the blower motor location and how to replace it. Check out the images (below). Let us know if you need anything else.
CHIP
I have little heat in the car and my fan does not work I have checked fuses what else could the problem be.
CHIP
[quote:2975a3f296="chip"]Heater problem
1998 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic 117000 miles
I have little heat in the car and my fan does not work I have checked fuses what else could the problem be.[/quote:2975a3f296]
Yes, if the blower motor is not working the heater will not work as well. Here is how to test he blower motor power and ground to make sure the motor is the problem.
https://www.2carpros.com/articles/how-to-test-an-automotive-hvac-system-blower-fan-motor-a-detailed
Here is the location of the blower motor and how to change it out. Check out the images (below). Let us know how it goes. You will need to cut the insulation to get at the blower motor.
MARK VANDUYNE
Heater problem
1996 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
Where can i find the plug for the heater? this is the second Grand Am I've owned on my last one I had the same problem and they found corroded terminals
JDL
  • 16,098 POSTS
Have you checked heater fuses? I don't know an easy way to get at the connector. You may have to access the blower motor and follow the wires.
The autozone site has info on getting at the blower motor. Click on( vehicle repair guides) follow the links for y--m--m, then type blower motor in their( parts search box), that page will have a link at the bottom for getting at the blower motor.
2CP-ARCHIVES
  • 4,540 POSTS
why would blower motor on heater just quit working
Nov 9, 2024 at 4:52 PM (Merged)
BLOWER MOTOR WILL NOT RUN
Check fuses. Turn ignition switch to RUN position. Check for voltage at function control switch. Switch blower switch to HI position. Check for voltage at switch and at high-speed blower relay. Ground blower motor with ignition switch in RUN position. If blower operates, motor is okay.
Check the blower motor fuse 30amp in engine compartment fuse center and blower relay in right rear in engine compartment-
Do this -you can power the blower motor purple wire and see if it works direct from the battery postitive post-
SSTARK
Heater problem
1996 Pontiac Grand Am 92788 miles
When I was recently on a long distance drive, I had the AC on in my car. When I switched it over to just the fan, the fan actually stopped working and i smelled something very hot. Then engine temperature was normal and the smell went away after just a minute or two. However, When I turn the fan or AC on, it barely blows anything out, and when I turn the fan speed up it doesn't change, but I get that hot smell. My dad thinks it's the blower resistor, do you have any suggestions and what would the instructions for changing the resistor be?
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be thinking that the fan motor is at fault.often you blow only one circuit of the resistor and the fan will still work on other speeds, check this out first.
mark (mhpautos)
SSTARK
I have already tried to use the fan on different settings and the speed doesn't change. I also get that hot smell when I try to turn the speed up. It will blow when it is on setting 1 however it barely feels like anything is coming out.
TERRYR65
Heater problem
1995 Pontiac Grand Am
blower motor keeps blowing fuses
BLUELIGHTNIN6
  • 16,542 POSTS
If a fuse keeps blowing, it usually means something is faulty in the circuit. The wiring should be checked along with the components in the circuit to determine if there's a short or other problem. If a fuse blows in a motor circuit (heater blower motor, cooling fan motor, power seat or window, electric fuel pump, etc.), it often indicates a shorted motor. In your case, I would suspect a faulty blower motor.
ED MOROS
Sunday the blower motor quit operating then later on it worked, Tuesday it quit again, I noticed that along with this the AC clutch does not engage when in ac mode or defroster mode , fuse ohms out as good, i don't believe it is the motor , but maybe the 'main rotary switch" next to the fan switch
At fuse block check the Heater/AC fuse 25amp. This problem could be the Heater/AC control assembly,blower motor resistor/blower motor relay located it in the right rear of engine compartment. See below
https://www.2carpros.com/forum/automotive_pictures/12900_blower_2.jpg
THE_ONE
Blower motor does not turn on i can feel the cold or the heat in the vent. I have removed the blower motor and had it checked and it works fine it turnd on but when I instaled it back in samething. I have also checked the fuses and there fine. One more thing, I have power windows and they stopped working at the same time the blower did I don't know if it's from the same thing. Please help!
SWEETAUTOG
  • 5 POSTS
this is a hard one with out the car but if yu have a test light or meter start checking fuses and relays one is drivers side dash and other is under hood below battery,also check your grounds.Hope this gets you on the right track.
BILL_LONGEST
a/c worked fine yesterday, today, blower (fan) is not working, i have checked the specific fuse for this function
SQM
  • 6,383 POSTS
An inoperative blower fan can be due to a faulty switch, bad relay, malfunctioning blower motor resistor, bad motor or wiring issue.
First check the relay.
The blower motor relay is located under the hood (see diagram).
Check for any corrosion or burnt pin(s).
You can also test the relay.
If the relay is good, then make sure the blower motor is getting power. To see if the motor is good or bad you can test it by simply applying 12V power to it.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Let me know what you find or if you have any questions.
Thank you.
KCCP586
There are 2 problems I cannot seem to pinpoint. First, As I accelerate, the headlights get brighter and the blower motor for the heating sytem runs higher. Also the ABS light will NOT go off. What could cause that. Second, When I put the car in Neutral and rev the motor up it hits a certain point and starts to whir I gues it sounds like a chattering rev. Up and down quickly. Any ideas??? Thank You
MMPRINCE4000
  • 8,548 POSTS
Have the charging system tested at most autoparts stores for free. Look for alt. output loaded and unloaded. Even if it is charging properly you may have a bearing in the alt. going south. Also check for proper belt tension and belt condition.
The test also includes a battery, starter test.
The ABS light is hopefully a wheel sensor that has worked loose, but you would need to get the car scanned with a chassis scanner to get the ABS fault.
Since this is an OBDI car, most likely you will have to get a trusted garage, or the dealer service scan the ABS system.
LBATAILLE
The fan for the heater works intermittenly in winter/ below freezing temps. Sometimes while I'm driving and hit a bump it will come back on after not working. Works fine in summer for A/C.
Also, where is the fan located? How do I go about getting to it? Do I need to take apart the dash?Thanks
The fan is located under the dash on the passanger side. And yes, you need to take part of the dash apart to access it. As far as the problem, it could be a bad blower motor relay that is reacting to the temp change. To be sure, you will need to check the fan to see if it is getting power when it isn't working. Also, I would also suggest making a new ground strap from the motor to a ground on the body to make sure it has a good ground.
KOOLAID
Hi I currently have a 1995 Pontiac Grand am se model with 3.1L automatic transmission and its got 101Miles on it
Recently the blower motor will cut off on its own, some days it will work and other days it wont work at all
please help as winter is coming I would love to get this resolved soon.
Regards
Alan
BMRFIXIT
  • 19,053 POSTS
[quote:64c4ceb2c2="koolaid"]Hi I currently have a 1995 Pontiac Grand am se model with 3.1L automatic transmission and its got 101Miles on it
Regards
Alan[/quote:64c4ceb2c2]
check the wires on the resistor and the motor
if all ok motor no good
JTADDY
Hey Alan,
I had the same problem in my 1992 pontiac grand am. It turned out for me to be the blower motor itself maybe a short or whatever me and a buddy replaced mine and it works like a charm. I ve been there hope this helps..... Josh
