1998 Pontiac Grand Am uneven braking
1998 PONTIAC GRAND AM
120,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMESROWLEY
the rear brakes seem to be working but the front brakes do not.
I have inspected the front brakes and all seems fine. nothing is siezed up the pads are good and I can bleed the brakes just fine.
Is there A sensor that would cause this?
Sep 10, 2009 at 1:40 PM
If you are getting pressure to the caliper when bleeding, then I would have to say the caliper piston is frozen. Check that first. Also, if that is good, you may have a problem with the master cylender or proportioning valve.
Sep 25, 2009 at 9:42 AM
