Engine Cooling problem
1998 Pontiac Grand Am 6 cyl Automatic 215000 miles
Car starts when engine is cold. Heats up to 240-250 degrees and turns off. Fan does not come on, replaced fuel filter and pump, water pump, flushed radiator and replaced radiator hose, replaced coil pack. After all this is still acts like it is not getting enough gas when it gets hot. Can you help me figure out if the ECT sensor needs to be replaced and would that effect the injectors in any way? Thanks for any suggestions you can come up with!
May 6, 2009 at 10:33 PM
