1997 Pontiac Grand Am White smoke coming through tail pipe
1997 PONTIAC GRAND AM
107,000 MILES • 6 CYL • 2WD • AUTOMATIC
VSHERMAN
I have white smoke coming through my tail pipe.
I change the oil and spark plugs and still there's white smoke. I also noticed a ticking sound in the engine.
What can I do to eliminate this problem?
Jan 3, 2009 at 6:48 PM
BRIAN 1
  • 1,030 POSTS
white smoke is engine coolant,vehicle is burning coolant.when you changed the sparkplugs were they very clean,and when you changed the oil was it milky and brown,these engines had alot of lower intake gasket leaks and head gasket failures.if you continue to run the car this way what will happen is the coolant will fill the engine and wash the oil off the cylinder walls and seize the engine,and the vehicle will overheat. this could be a very expensive fix.
Jan 3, 2009 at 8:56 PM
