1997 Pontiac Grand Am my brakes
1997 PONTIAC GRAND AM
95,346 MILES • 6 CYL • FWD • AUTOMATIC
PONTIAC FORM H@#$
i replace the caliper bolt on the passenger side front it was the bolt closest to the street i put the caliper back on and some how know i have no brake pressure i looked for leaks what should i do oh before i did this i had brake pressure
Mar 30, 2008 at 11:35 AM
TIMDOG
  • 4 POSTS
[quote:27ab8ade4c="pontiac form h@#$"]Brakes problem
1997 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 95346 miles
i replace the caliper bolt on the passenger side front it was the bolt closest to the street i put the caliper back on and some how know i have no brake pressure i looked for leaks what should i do oh before i did this i had brake pressure[/quote:27ab8ade4c]
did you remove a brake line before you put the ca;iper back on?
if so,it looks like you didn't bleed the line after you put the caliper back on.
Mar 30, 2008 at 12:24 PM
