1997 Pontiac Grand Am bleeding hydraulic clutch lines
1997 PONTIAC GRAND AM
105,000 MILES • 4 CYL • FWD • MANUAL
SKTS63
I just replaced the clutch in my grand am. The slave cyl is internal with an external bleeding screw. I have gravity bled the system but can't seem to get decent pedal pressure. can you walk me through the best way to get all of the air out of the line?
Mar 27, 2009 at 2:49 PM
MMPRINCE4000
  • 8,548 POSTS
Gravity bleed should work, fill clutch MC to full and bearely loosen slave bleeder until all air is out of system.
If problem persists, then the clutch MC seal is bad (assuming slave was installed correctly).
Mar 30, 2009 at 9:52 AM
