1996 Pontiac Grand Am Radiator fan....
1996 PONTIAC GRAND AM
108,260 MILES • 4 CYL • FWD • AUTOMATIC
BIGROBERTO2008
  • 8 POSTS
hi , i heard alot things about my car and the flaws that they have through forums, friends and what not, my key experience while owning this car has been overheating....when i first got the car of course it had problems, but all i had to do was fix it, so far since last year mid summer i had a new water pump, new thermostat, and recently a new radiator. But for some strange reason my car runs about 3/4 on the engine temperature after its warmed up and drivern for a while, it does not get past 3/4 but its pretty up there, and i wanted to know if this is the normal temperature for these cars?? Also my fan belt DOES work (if thats what its called) but its not doing enough in my opinion. Is it also possible to install a second fan belt? Seeing as how most cars have two and mines have only one??
Jul 5, 2010 at 2:17 AM
MMPRINCE4000
  • 8,548 POSTS
Temp gauge uses a seperate sender for gauge, so sender or gauge may be bad.
To confirm, scan PCM in live data and observe PCM coolant temp vs. gauge reading.
Jul 5, 2010 at 9:32 AM
BIGROBERTO2008
  • 8 POSTS
I have already replaced the temperature sender a while back last year and it helped out a little , but its still getting close to the red zone around 3/4 and up. Mostly this happens on a really hot day but as the temperature drops outside it doesn't overheat that much at all. Is it that the thermostat is going bad again?, because i also replaced it last year as well.
Jul 19, 2010 at 11:53 PM
MMPRINCE4000
  • 8,548 POSTS
Could be a cooling fan problem, or waterpump.
Check that fans work first.
Jul 20, 2010 at 8:30 AM
BIGROBERTO2008
  • 8 POSTS
The fan does work and at full speed, the waterpump could be a concern for me because i had it replaced last year but bascailly i replaced the entire cooling system, ( radiator,waterpump, thermostat and had the coolant system flushed) i have not however had the intake checked, could that be the problem??
Jul 20, 2010 at 10:51 PM
MMPRINCE4000
  • 8,548 POSTS
GM had many problems with intake gaskets, they recalled 3.1, 3.4, and 3.3, 3.8 engines.
Jul 21, 2010 at 6:55 AM
BIGROBERTO2008
  • 8 POSTS
do u know if they ever recalled 2.4 se models?
Jul 27, 2010 at 12:14 PM
MMPRINCE4000
  • 8,548 POSTS
Not that I am aware of.
Check cooling system with a pressure test.
Jul 28, 2010 at 8:13 AM
