Disconnect the negative battery cable.
Using a drive belt tension wrench, rotate the tensioner.
Remove the drive belt from the alternator pulley.
Support the engine at the oil pan
Remove the engine mount assembly from the bracket support.
Unbolt and remove the auxiliary bracket.
Lower the engine and extract the drive belt.
To install:
Rotate the belt tensioner.
Place the drive belt around the pulleys and attach the auxiliary bracket. Tighten the bracket fasteners to 37 ft. lbs. (50 Nm).
Install the engine mount to the support bracket bolts. Tighten the bolts to 96 ft. lbs. (130 Nm).
Remove the floor jack and block of wood.
Connect the negative battery cable.
Start the engine and check for any out of the ordinary noises.
Thanks for using 2CarPros.com!
Mar 12, 2009 at 2:20 PM
