1995 Pontiac Grand Am will not shift
1995 PONTIAC GRAND AM
150,000 MILES • 4 CYL • FWD • AUTOMATIC
MEHOLE
The transmission will shitf from park to reverse to nutral and to first but it will not shift above that, what i dont understand is that it worked fine a year ago when i first got it and it sit for a while now it wont work. the fluid is full. i have ran out of options and i dont have the money to take it to the shop!!
Nov 30, 2008 at 7:56 PM
MMPRINCE4000
  • 8,548 POSTS
Check the cable connection to the trans, make sure it is moving when the selector is moved.
Dec 1, 2008 at 8:29 AM
MEHOLE
yes everything moves on the exterior of the trans and in the pan!!
Dec 1, 2008 at 7:13 PM
MMPRINCE4000
  • 8,548 POSTS
If the selector cable is working properly, and is moving the selector arm on the trans. to all the gears P-R-N-D-2-1, and the fluid is full (always check with engine running, trans at temp. car in Park)then you will have to get it inspected at a trans shop for a diagnosis. Some will do it for free, and use a local shop, not a chain.
Dec 4, 2008 at 10:28 AM
