1995 Pontiac Grand Am Replace Brake Shoes tire now shaky
1995 PONTIAC GRAND AM
LWILLIS
Tires and Wheels problem
1995 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
We have replace the brake shoes on the bake of the car. The drum goes on tight, wheel goes on and the lug nuts are tight. There is a slight bit of play in the tire and when driving it is wobbling. I have taken the tire off three times and checked and retightened. What else could it be, it seems like the play is coming form the drum, but the lugs cannot be tightened any more.
Feb 26, 2010 at 2:16 PM
BASSTECH
  • 236 POSTS
sounds like you have a loose wheel bearing.
Install the wheel on the car and see if you can move / shake it while it's attached. If you can, most likely it needs a wheel bearing.
Sometimes they make a noise like truck is behind you...
let me know how you make out...
Feb 26, 2010 at 4:49 PM
