interior lite are not working,no fuse are broken or missing.
Feb 2, 2009 at 10:35 AM
JDL
CERTIFIED EXPERT
Are you talking about the courtesy lamps? My info shows fuse 28, 15 amp, the fuse circuit should be hot all the time, that circuit goes to the alarm module then to courtesy lamps. I believe the ground circuit also goes to the alarm module. Can you turn on the courtesy lamps using the lite switch?
