Replacement ECM's are generally sold without PROM chip. You must remove old PROM from ECM and install in replacement ECM.
A small cover on ECM houses the PROM and gently remove old PROM and install on new ECM. Make sure not to bend the small pins on PROM chip.
This is all done with battery disconnected. When you install the new ECM, reconnect battery and ECM will "relearn" correct parameters. It will do this over a period of a few days of normal driving.
Dec 7, 2020 at 4:26 PM
(Merged)
