oil pan removal
1994 PONTIAC GRAND AM
SPINNERWILEY
Engine Mechanical problem 4 cyl Front Wheel Drive Automatic
how do i get the oil pan off? I can't reach all the bolts. The front motor support bracket is in the way and i can't get it to come off.
Dec 24, 2008 at 11:39 AM
MMPRINCE4000
  • 8,548 POSTS
You will have to loosen or remove all the motor mount bolts and raise engine (just a few inches) with a cherry picker to get to the pan bolts.
Dec 25, 2008 at 7:26 AM
RANDY T BRADFORD
Mine is a v6 ..same year 94 ...do I have to raise motor too ??
Jul 14, 2017 at 6:54 AM
You will need to jack the car up first and then drain the oil.
Here are some diagrams to help you get the job done.
Jul 17, 2017 at 10:25 AM
