Hello, When I start the motor the idle goes to 1500 rpm or so. It will climb to around 3,000 once warmed up. It will not kick down. I can shut it off and restart it but still high idle. I drive 48 miles to work. The idle is still around 2,000 when I get there. Every once and a while it will idle down. The computer says "Idle position sensor" I replaced that and no change. The code still comes up on the system.
Thanks,
Russ
Thanks,
Russ
Feb 25, 2008 at 7:41 AM
