My bake lights do not work I've checked the bulb and the fuse and they all look fine. What else could be the problem?
Feb 28, 2008 at 4:09 PM
MERLIN2021
CERTIFIED EXPERT
Look at the brake pedal, travel up the arm, you will see the stop light switch, first push it towards the front of the car, then pull up on the pedal, check for lights, if still not working, replace the switch, and redo these steps!
