I took my car in to the mechanic because the water pump blew and when i got it back, it wont shift. Mechanic replaced the water pump and serpentine belt, and car starts and runs great. I checked the TV cable and it was very worn, so i removed it and drove around to see if for some reason that was why but the problem remains. I have checked the linkage and it seems to be fine, car starts in park and neutral, reverse and drive engage and neutral is normal. Does not move in park so the transmission is shifting manually, but the thing wont go out of 1st! Fluid level is in operating range, actually a little over full... could that be the problem? I have been running it at the current fluid level for 12k miles so im just at a loss.
Nov 7, 2009 at 9:36 PM
