Here is the problem - after I have driven for a while (30 - 40 minutes) at a higher speed (60-70 mph), I will slow down and attempt to stop. However, when I hit about 20 mph my engine will begin to run really rough. As I slow down more, it runs rougher and rougher and as I come to a stop it will die. If I attempt to go faster and give it more gas, it will not speed up and continue to run rough. It will start up fine, but it will occasionally stall as soon as I put it in gear (immediately after the initial stall - it always starts fine when cold), although it has always taken off and worked just fine eventually.
This has never happened when I drive 10-15 miles around town, only after driving a more significant distance. Any ideas? Thanks so much in advance!
Jul 8, 2009 at 1:18 AM
