My check engine oil lite comes on briefly every so often, I think it is a connection at the engine but where do I find what to look for
Dec 10, 2009 at 5:59 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
is your engine oil at full level? if it is then it may be a weak oil pump causing this or a fualty oil sending unit. sending unit should be near oil filter housing.
Dec 18, 2009 at 4:29 PM
CALLSIGN
MEMBER
Thank you, I will look there and yes the oil level is full
