1993 Pontiac Grand Am BRAKES
1993 PONTIAC GRAND AM
98,000 MILES • 4 CYL • FWD • AUTOMATIC
KEVIN M. GRIFFIN
THE RIGHT FRONT CALIPER IS STICKING. i HAVE REPLACED THE CALIPER, BRAKE PADS AND BLED THE BRAKES. I ALSO REMOVED THE NEW CALIPER, PUT ANTI-SEIZE ON THE BOLTS AND RE-INSTALLED. IT STILL STICKS. I BELIEVE IT'S THE MASTER CYCLINDER BECAUSE IT WILL NOT RELEASE WHEN THE KEY IS TURNED OFF, ONLY WHEN I BLEED THE PRESURE OFF OR OVER A PERIOD OF TIME.
Dec 25, 2007 at 5:33 PM
BMRFIXIT
  • 19,053 POSTS
[quote:e0ccd72236="KEVIN M. GRIFFIN"]Brakes problem
1993 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic 98000 miles
THE RIGHT FRONT CALIPER IS STICKING. i HAVE REPLACED THE CALIPER, BRAKE PADS AND BLED THE BRAKES. I ALSO REMOVED THE NEW CALIPER, PUT ANTI-SEIZE ON THE BOLTS AND RE-INSTALLED. IT STILL STICKS. I BELIEVE IT'S THE MASTER CYCLINDER BECAUSE IT WILL NOT RELEASE WHEN THE KEY IS TURNED OFF, ONLY WHEN I BLEED THE PRESURE OFF OR OVER A PERIOD OF TIME.[/quote:e0ccd72236]
replace caliper flex hose
Dec 25, 2007 at 9:10 PM
