1993 Pontiac Grand Am bleeding the cooling system
1993 PONTIAC GRAND AM
119,000 MILES • 6 CYL • FWD • AUTOMATIC
CCRACING84
to bleed the cooling system where do i have to look to bleed the air out cause there is no where to bleed it by the thermostat, is there somewhere else that i could bleed the air out?
Dec 16, 2008 at 3:22 PM
BUDDYCRAIGG
  • 2,262 POSTS
stand in front of the car.
looking at the engine.
there is a pipe that runs above the valve cover that is closest to you
at the end of that pipe on the passenger side is a bleed valve.
it may not look like what you are used to seeing on brakes.
Dec 16, 2008 at 8:32 PM
