1988 Pontiac Grand Am back firing
1988 PONTIAC GRAND AM
98,000 MILES • 4 CYL • FWD • AUTOMATIC
GREASEYJESSE
  • 5 POSTS
when step down on trottle starts to cut out real bad if you dont leave off the gas it will back fire and shut off it is a 2.5 distriberless ignition could a coil pack do this
Dec 6, 2008 at 10:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Usually a tune up will rid your vehicle of a backfire issue. Have plugs, wires, fluids, filters etc... inspected/replaced. Use OEM plugs and wires from dealer as these components are usually a little cheaper made at parts stores.
Dec 6, 2008 at 10:53 PM
GREASEYJESSE
  • 5 POSTS
[quote:078f9447d3="bluelightnin6"]Usually a tune up will rid your vehicle of a backfire issue. Have plugs, wires, fluids, filters etc... inspected/replaced. Use OEM plugs and wires from dealer as these components are usually a little cheaper made at parts stores.[/quote:078f9447d3]it has alreadh had a complete tune including all filters
Dec 10, 2008 at 8:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, good. Check the timing. This can also cause backfire. It could also be a worn distributor.
Dec 11, 2008 at 12:06 AM
GREASEYJESSE
  • 5 POSTS
[quote:7b451563d0="bluelightnin6"]Okay, good. Check the timing. This can also cause backfire. It could also be a worn distributor.[/quote:7b451563d0]this car has distriberless ignition
Dec 15, 2008 at 3:49 PM
