speedometer problem?
2006 PONTIAC G6
BGOELTZ
Transmission problem 6 cyl Front Wheel Drive Manual 76000 miles
I had quick onset of problems with my speedometer. Within the last six or seven days the speedometer needle would "slip" slightly and read lower momentarily (e.g., it would "slip" to 35 or 30 when I was going 40). This has progressed over the last week or so to the point that the needle would slip dramatically (e.g., from 60 to 45 to 30 and then back up in a similar manner to 60 again). Eventually, the speedometer needle just fell to zero while I was driving, I got an "error" message on my digital odometer, and the engine light came on. Now the needle recovers very erratically and the engine light stays on.
As far as I can tell, I've had no corresponding engine performance problems (e.g., no loss of power, no revving, etc). The only other thing I've noticed is that the automatic volume leveling feature on my sound system has fluctuated along with the speedometer needle. Thanks VB
Mar 13, 2009 at 6:03 PM
This is an easy one your VSS vehicle speed sensor is not working right I would replace it which should fix the problem.
Here is the location (below)
Please let us know what you find.
May 22, 2009 at 4:44 PM
BGOELTZ
Yep you got the problem, I replaced the sensor like you said and the speedo works great no check engine light on ya! the sensor cost me $34.00 this site rocks!
May 26, 2009 at 4:40 PM
