2006 Pontiac G6 Change fluid
2006 PONTIAC G6
98,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHNLMILLER
How do I change the transmission fluid and filter and then how do I get the new fluid into the transmission. It does not have a dip stick
Sep 22, 2010 at 10:46 AM
WRENCHTECH
  • 20,761 POSTS
This is not really something you want to attempt yourself. First off, the best way to do this is with a transmission total fluid replacement machine. There is a level check plug in the side and fluid has to be pumped back in. Simply draining it will only get about 1/3 of the total fluid anyway.
Sep 22, 2010 at 11:01 AM
