2006 Pontiac G6
2006 PONTIAC G6
29,500 MILES • 6 CYL • FWD • AUTOMATIC
NPRIMO85
I have a 2006 Pontiac G6 GTP Coupe. I notice at speeds 40mph till about 55mph, the steering wheel has a slight vibration in it. Could it just be as simple as a wheel balance solution? 3 of the tires are the orginal tires, could that be the issue?
Mar 10, 2009 at 6:39 PM
BMRFIXIT
  • 19,053 POSTS
Would be 1st to check
(tires and wheel balance )
if tires all OK have them balanced
Mar 10, 2009 at 7:23 PM
NPRIMO85
Okay, thanks. Also when stopping at highway speeds, there is a vibration in the pedals/steering wheel. Could that be a warped rotor? I have had them machined twice since I had it.
Mar 11, 2009 at 5:29 PM
BMRFIXIT
  • 19,053 POSTS
Its time for new brake job and make sure you install new rotors too
good luck
Mar 11, 2009 at 5:35 PM
NPRIMO85
thanks
Mar 11, 2009 at 7:30 PM
