does it have a SES light on?that could make it not remote start,here are other reasons also.The RVS System WILL NOT operate if any of the following conditions are present:
• A current vehicle DTC that illuminates the malfunction indicator lamp (MIL) is set - obtain vehicle DTCs.
• Keyless Entry Transmitter is not Operational.
• The vehicle is in Valet Mode.
• RVS is Disabled through Vehicle Personalization.
• More than 2 Remote Starts have been attempted.
• The HAZARD switch is in the ON position.
• A current HAZARD switch DTC is set.
• A current HOOD AJAR DTC is set.
• Rear compartment lid is ajar.
• Any Door is not locked.
• The Content Theft Deterrent (CTD) system detects an alarm trigger.
• Engine RPM greater than 0 Detected.
• Excessive Coolant TEMP is registered.
• Accelerator pedal position greater than 0 percent.
• Vehicle is not in PARK.
• A current Vehicle Theft Deterrent Malfunction DTC.
• A current Automatic Transmission Shift Lock Control System DTC is set.
• A vehicle speed sensor signal is detected by the ECM.
• Vehicle power mode is incorrect.
also a faulty hood latch switch,there is an updated hood latch switch. post back with any other questions.
Dec 8, 2008 at 7:01 PM
