Shallow "knocking" noise - '99 Firebird
1999 PONTIAC FIREBIRD
THATGUY8898
I have a shallow knocking noise in my firebird. It sounds like a beer can bouncing on a fan blade. The noise happens mostly while in gear, and accelerating. It doesn't happen in reverse, or in neutral. If I am accelerating, and I let off of the gas, the noise stops. If I am accelerating, and I throw it in neutral, and hit the gas again, it stops., but comes back as soon as I put it back in gear, and continue accelerating. The noise also appears (sometimes) if I am stopped on an incline, or if I put the car in park on an incline. I am lost, and have no idea what this is. Any help would be appreciated. Thanks.
P.S. This noise doesn't effect the performance. The car shifts fine (it's an automatic), and accelerates fine. The noise almost sounds like it's coming from the transmission/starter area, but not really sure.
Feb 19, 2007 at 7:44 PM
KIN CHAN
  • 453 POSTS
chk around drive shaft area ...also theck U- joints ..best way to find it is to jackthe car up(BE CAREFUL) put it in gear and have some1 look at all moving parts from under.....or try lord vader and use the force...heh heh heh heh
Feb 19, 2007 at 9:49 PM
