2002 Pontiac Firebird RIMS
2002 PONTIAC FIREBIRD
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
ABUCKNER31
OK NOT REALLY A REPAIR QUESTION BUTT HOPEFULLY YOU WILL HELP ME OUT I WOULD LIKE TO KNOW IF AFTERMARKET RIMS OFF A MITSUBISHI GT3000 WILL FIT ON A 2002 PONTIAC FIREBIRD SRY FOR THE INCONVIENCE
Nov 24, 2008 at 11:39 PM
KEVIN12881
  • 336 POSTS
be careful before you go around changing rim size's and tire sizes. Even if they do fit, wich you can tell by measuring, that may not be a good idea. When you change the size of your tires from the ones suggested by the factory you will have side effects. ie.. loss is MPG from arodynamics. and different rims are rated for different weght and abuse.. Stick with G.M rims, if you want cooler then get corvette rally rims... Plus no GM car fan whants to see import rims on a fire bird
Nov 25, 2008 at 5:40 PM
